clunckin noise when driving over bumps
i gotta 04 a6. i gotta noise i cant find what it is. when turning and going over bumps it makes clunking noise in the front end. Anybody know what this might be
Take a good look at all your suspension ... I had a clunking noise as well and after a good look over I could see the bushings on the sway links were toast. Spent less than $100 and did them myself and noise is all gone. YEAH!
Also with the inspection I could tell I need to start to plan to install some new bushings on the control arms--more so will just do the entire swap so it has fresh ball joints as well.
"ImTheDevil" is right, there are a few things to consider, just take a good look at everything, hope you find out the problem as easy I did.
Well I replaced all the control arms (with bushings) and all 4 struts + the front axles during a 4 day maintenance week, that's when my clonking started.
Anyhow for me it was the clamp of the sleeve for the Tie rod end - simple and easy fix.
I hope it's something simple for you
