Code 0068 MAF/MAP sensor
Old Jan 21, 2010 | 01:40 PM
jverdura's Avatar
Default Code 0068 MAF/MAP sensor
My check engine light has been on and off for a few weeks, finally had a friend plug in his computer to find the code. It said 0068 MAF/MAP sensor Throttle position correlation. It's a 2006 A6 Avant.
Any ideas what this means. The car runs perfect and have not seen a change in gas mileage.
Thanks in advance!
Old Jan 21, 2010 | 08:58 PM
Jackmup's Avatar
It could be a few things.
First clean your MAF sensor and the terminal that plugs into it make sure the female connectors are tight and I slide a nail file over the male connectors to scratch them up a little then apply dielectric grease to keep moss from forming.
If that doesn't do it try this;
https://www.audiforums.com/forum/sho...d.php?t=141756
If your still having problems your MAF may be bad but it's not running like crap sounds like it could just be a loose connection and the computer is loosing signal once in a while.
I had the same code and replaced my MAF but it ended up being the throttle control. My rpm bounced up and down in the morning and the car was jumpy off the line. After i cleaned it it's been great. I notice any time it gets really cold I loose connections on something or another.
s31523
Jan 14, 2018 01:14 AM
vtraudt
Mar 31, 2011 10:11 AM
brian58503
Apr 30, 2009 10:07 AM
purrfecht
Nov 2, 2007 03:23 PM
dmayer75
Jun 19, 2007 08:22 AM
