CODE 30-10 - Open or Short to B+ -
Old Aug 27, 2009 | 12:32 AM
vrso2's Avatar
Default CODE 30-10 - Open or Short to B+ -
hmm, anybody has some idea ?
01582 - Signal for Coolant Temperature
30-10 - Open or Short to B+ - Intermittent
Which sensor is it ?
Old Aug 27, 2009 | 09:08 AM
Jackmup's Avatar
It's for the A/C coolant temp.
Either the sending unit is bad a wire is shorting out or the instument cluster is malfunctioning.
Intermittant signal - I would check your wires and test the sensor/sending unit. make sure the connections are tight and clean the pins.
Old Aug 15, 2019 | 10:33 AM
vtraudt's Avatar
Default AC coolant temp sensor error
IS there a sensor for that? Or is the instrument cluster or ECU REPORTING the coolant temp (as measured by the coolant temp sensor G62) to the HVAC module?
ahmad sabra
Sep 28, 2012 11:28 AM
Uberman52
Oct 2, 2011 11:29 AM
audib5971
Mar 8, 2009 07:34 PM
daghstdrummer
Jun 7, 2007 01:11 PM
bcart82
Mar 21, 2007 11:14 PM
