Code P0431 Where is this cat located?
I have a 01 A6 2.7t...and it keeps throwing code P0431 every couple days after i erase it...I know that its either a cat going bad or a bad 02 sensor...where at and which side is it located because i was planning on fixing it myself. Thanks
Basically this means that the oxygen sensor downstream of the catalytic converter on bank 2 is detecting that the converter is not working as efficiently as it should be (according to specs). It is part of the vehicle emissions system.
A code P0431 may mean that one or more of the following has happened:
* The catalytic converter is no longer functioning properly
* An oxygen sensor is not reading (functioning) properly
* There is an exhaust leak
Possible Solutions
Inspect for exhaust leaks. Next step is to measure the voltage at the oxygen sensor on Bank 2. In fact, it would be a good idea to test each oxygen O2 sensor while you're at it.
Possible Solutions
