Sponsored by:
Sponsored by:
Code P0431 Where is this cat located?
Old 11-02-2008, 10:08 AM
playboy00786's Avatar
Default Code P0431 Where is this cat located?
I have a 01 A6 2.7t...and it keeps throwing code P0431 every couple days after i erase it...I know that its either a cat going bad or a bad 02 sensor...where at and which side is it located because i was planning on fixing it myself. Thanks
Old 11-02-2008, 10:54 AM
Retard Riot 686's Avatar
Basically this means that the oxygen sensor downstream of the catalytic converter on bank 2 is detecting that the converter is not working as efficiently as it should be (according to specs). It is part of the vehicle emissions system.
A code P0431 may mean that one or more of the following has happened:
* The catalytic converter is no longer functioning properly
* An oxygen sensor is not reading (functioning) properly
* There is an exhaust leak
Possible Solutions
Inspect for exhaust leaks. Next step is to measure the voltage at the oxygen sensor on Bank 2. In fact, it would be a good idea to test each oxygen O2 sensor while you're at it.
Old 11-03-2008, 09:36 AM
hxgaser's Avatar
P0431 on 2.7 can also be triggered by the low threshold on the ECU. The dealer can reflash the ECU.
emmeffsee
04-15-2011 10:21 AM
garcilla
08-19-2010 07:21 AM
twinturbosixer
04-15-2009 11:25 AM
S4Goose
09-29-2007 01:32 AM
jlewis166
09-08-2007 09:06 AM
Quick Reply: Code P0431 Where is this cat located?
