control arms
Old Jan 2, 2008 | 07:16 PM
Lilo Shark's Avatar
Default control arms
ok, so the dealer told me that the front leftlowercontrol arm was bad, but didn't tell me which one. so how do you check if it's the rear postion or front postion control arm? my options for rear postion are Febi or Lemforder,which one is a better choice? for front postion are First equipment, Febi, and TRW.
alsomy sway bar links are bad i found some stuff on alleuropeanautoparts.com but is there anywhere else i should look?
Old Jan 3, 2008 | 01:27 PM
2k S4's Avatar
Default RE: control arms
DO ALL OF THEM ON BOTH SIDES!
If one has failed, all are on the way. You need a wheel alignment after. If you do just one, get the alignment done, then a month later you will need to it all over again.
Both kinds are good.
jdahlen24
Aug 25, 2011 09:50 PM
jdahlen24
Aug 25, 2011 03:05 PM
audiboy31790
Aug 20, 2008 11:07 PM
Tonyd
Aug 10, 2005 09:33 PM
Tonyd
Aug 9, 2005 01:02 AM
