Coolant Leak
Old Jun 3, 2010 | 10:29 AM
berg's Avatar
Default Coolant Leak
I just bought a 2000 A6 QUATTRO 2.7T and I am having a coolant leak, I took it to 2 different places and they said nothing was wrong with it. So I am guessing there is a cracked line or something underneath. Has anyone had a problem like this? Or any idea? It leaks pretty bad, I have lost all the coolant twice. So I dunno how they say there is nothing wrong But I am planning on putting it up on the stands today and taking a look at the lines.
Old Jun 3, 2010 | 10:38 AM
histeel's Avatar
depends on where the leak is coming from front of engine thermostat plate can leak could be aux water pump under manifold (pita) rear of engine crossover coolant pipe.
Old Jun 3, 2010 | 12:56 PM
berg's Avatar
its on the driver side mostly, there is a support to the right of the engine (driver side) that has coolant sitting on it so I kinda ruled out engine. But I dunno...
Old Jun 3, 2010 | 01:05 PM
jhuffman's Avatar
Maybe check the coolant temp sensor. The black ones (OEM) are prone to cracking and leaking. Check and make sure you have the green updated one.
Old Jun 3, 2010 | 02:08 PM
berg's Avatar
Ok ill check that out. Behind the motor isnt it?
I tried using my Vag Com but I couldnt figure out how to use it. In that time I sat in my car for 10 minutes and there was a big puddle of it and the gauge was one past the medium line and there was steam or smoke coming from around the engine. Not good.
Old Jun 3, 2010 | 04:16 PM
jhuffman's Avatar
If it looks like its coming from the bell housing, or the intake manifold area its probably your aux water pump. They are prone to failure.
Old Jun 3, 2010 | 06:01 PM
histeel's Avatar
check your reservoir it could be cracked.
Old Jun 3, 2010 | 07:28 PM
UberTeile's Avatar
A pressure test would probably find your leak quickly...but the above mentioned areas are good places to look.
Cioffie
May 19, 2013 10:24 PM
azr3al
Dec 30, 2011 12:37 PM
supacor24
Jun 3, 2011 07:56 AM
inventorA6
Apr 15, 2009 06:46 AM
less_of_me
May 2, 2007 03:29 AM
