coolant leak
Old Mar 15, 2007 | 03:06 PM
S4sweeteeteeRS's Avatar
Default coolant leak
I got an 03 A6 2.7T (not under warranty) with a slow leak in the coolant. Apparently, it’s expensive to fix because of the location (mostly labor cost). If I’m aware of it, check and fill when needed, does it do more harm to just let it go? I don’t know how long I plan on keeping the car.
Also, any good DIY ideas for repairing scuffed stock wheels?
Old Mar 16, 2007 | 12:51 AM
mpw2.7T's Avatar
Default RE: coolant leak
Did they tell you that it's the aux coolant pump? That's what it sounds like. $150 part and 5 hours of labor. It will just continue to get worse for a while, but I have heard of them failing catastrophically. That could leave you stranded. On top of that, the G12 coolant gets pretty expensive if you are topping up frequently.
Old Mar 22, 2007 | 04:39 AM
Cmoney's Avatar
I have a 2000 2.7. I had the auxillary pump start leaking. It got worse and worse. I got tired of buying that expensive coolant. I had it fixed under warranty for $100. It was an $850 repair because they had to undo the manifold to get to the pump. Yeah, the labor is much more than the actual parts. Good luck
Old Mar 22, 2007 | 09:45 PM
ppgoal's Avatar
I had my auxiliary water pump replaced when they were putting in the new clutch/flywheel. The part was $114 and there was 3 hours labor.
Cioffie
May 19, 2013 10:24 PM
azr3al
Dec 30, 2011 12:37 PM
supacor24
Jun 3, 2011 07:56 AM
inventorA6
Apr 15, 2009 06:46 AM
less_of_me
May 2, 2007 03:29 AM
