coolant leak/loss
Old Oct 20, 2009 | 10:11 AM
jchaffee1's Avatar
Default coolant leak/loss
i noticed the other day my coolant level is well below the low mark...what are common places to lose coolant? can coolant be lost due to heat on long trips if the engine oil gets a little low?
Old Oct 21, 2009 | 09:39 AM
bob martin's Avatar
Common places for coolant to leak are:
- water pump
- secondary water pump if you have the 2.7
- various hoses
- head gasket
- heater core
Start by filling the coolant up and seeing if it stays up.
If not, place a clean sheet of cardboard or newspaper under your car and letting it sit overnight. See if you see any wet spots. If you do, follow the drip up the engine until you find the source of the leak. Using a white spray powder, such as foot powder, can help you track the drip up to the source.
When you get that far, let us know and we can advise from there.
Bob
Old Oct 21, 2009 | 12:52 PM
NH_USA's Avatar
Ya left out the expansion tank cracks!!
Old Oct 21, 2009 | 01:09 PM
ppgoal's Avatar
You'll need to remove the plastic belly panel so the leak does not get dispersed or puddle on the panel.
Old Oct 21, 2009 | 03:06 PM
jchaffee1's Avatar
i should be able to get a good look at things when i do my timing belt in the next couple of weeks. don't even know if its a recent thing or just a slow burn/leak since i haven't added any (since ownership) in 45k miles (140k total now), nor really paid any attention. it took 1 liter total fluid (mixed) to level it back off.
Cioffie
May 19, 2013 10:24 PM
Taza
Dec 2, 2012 02:14 PM
cuszb5
Jan 22, 2010 09:55 PM
_Adrian_
Nov 13, 2006 06:00 AM
alunthomas
Sep 16, 2005 02:05 PM
