Coolant leak from T-piece
Ok...so my t-piece broke and I replaced it. Well after I did it started leaking from two places around it...here are some pictures.
What can I do to stop it? Use different clamps? The kind that I can screw to tighten?
[align=right] [/align]
RE: Coolant leak from T-piece
But, it did not leak before I changed the T-piece...so could I have damaged the fibers?
Or do you think that the screw type clamps might work?
And it is a pretty significant leak...one which I do not think that the fibers could handle...maybe. I do not know much about this.
Yeah try the clamps first, they are highly replaced items and we stock them at most dealers.
They will give you a picture off ETKA in the parts department to identify the hoses but more than likely the parts guy will know which hoses they are.
Yeah, I do not know if you can tell or not, but it seems that the original clamps are not as tight on there as before. I lined them up with the indentions and they are about 2 mm not as tight.
Also, is it possible to replace the plastic T with something from a different material? If, so what would be recommended?
I wasnt at all. I just try to get it off gently without breaking the T- Also, is it possible to replace the plastic T with something from a different material? If, so what would be recommended?
And how much do these hoses go for? Would you happen to know?
