Sponsored by:
Sponsored by:
Coolant leak from T-piece
Old 08-12-2007, 05:50 PM
MiniSpdRcr's Avatar
Default Coolant leak from T-piece
Ok...so my t-piece broke and I replaced it. Well after I did it started leaking from two places around it...here are some pictures.
What can I do to stop it? Use different clamps? The kind that I can screw to tighten?
[align=right] [/align]
Old 08-12-2007, 06:32 PM
auditech79's Avatar
Default RE: Coolant leak from T-piece
Try screw type clamps, usually you have to replace the hoses cause they leak through the fibers inside the hose which you can't stop.
Old 08-12-2007, 06:57 PM
MiniSpdRcr's Avatar
But, it did not leak before I changed the T-piece...so could I have damaged the fibers?
Or do you think that the screw type clamps might work?
And it is a pretty significant leak...one which I do not think that the fibers could handle...maybe. I do not know much about this.
Old 08-12-2007, 07:31 PM
auditech79's Avatar
Taking them off is what breaks them, once you twist the hose to get it off the T you tear the fibers.
Old 08-12-2007, 07:35 PM
MiniSpdRcr's Avatar
Well I will give the screw type clamps a try. If not what are the hoses called and are they easy to replace? Also where could I get them?
Old 08-12-2007, 07:45 PM
auditech79's Avatar
Yeah try the clamps first, they are highly replaced items and we stock them at most dealers.
They will give you a picture off ETKA in the parts department to identify the hoses but more than likely the parts guy will know which hoses they are.
Old 08-12-2007, 07:50 PM
MiniSpdRcr's Avatar
Yeah, I do not know if you can tell or not, but it seems that the original clamps are not as tight on there as before. I lined them up with the indentions and they are about 2 mm not as tight.
Also, is it possible to replace the plastic T with something from a different material? If, so what would be recommended?
Old 08-12-2007, 07:52 PM
auditech79's Avatar
The smaller factory clamps really do suck, if you weren't too aggressive with removing the plastic T you have about a 50% chancea screw type clamp will fix it.
Old 08-12-2007, 07:53 PM
MiniSpdRcr's Avatar
I wasnt at all. I just try to get it off gently without breaking the T- Also, is it possible to replace the plastic T with something from a different material? If, so what would be recommended?
And how much do these hoses go for? Would you happen to know?
Old 08-12-2007, 07:56 PM
MiniSpdRcr's Avatar
Also, if it was leaking through the threads would it be a bad leak? Mine is pretty significant.
Quick Reply: Coolant leak from T-piece
