Coolant Question
Old Feb 11, 2007 | 04:22 PM
RHarris567's Avatar
Default Coolant Question
New to the forum....but I have a problem (on a Sunday) of course! Ibought a used 1998 Audi A6 Quattro. The "Coolant Level" light has started coming on after I drive for 10 minutes. I stopped at a service station and they didn't think it looked low. But when I checked it this morning with a cold engine...it is slightly below the minimum level line. Can I buy Audi coolant (this is pink) at a local auto parts store today? And if it is not an exact match...will that be a problem? I have no idea what the type is that is in the resevoir now. Also...can I add water to the coolant...and if so...how much?? Thank you.....
Single Mom with no auto tech experience!!!!
Old Feb 11, 2007 | 04:50 PM
Jeffla's Avatar
Default RE: Coolant Question
You need to get the coolant from the dealer. I suggest just waiting until tomorrow and stopping by the VW or Audi dealer and getting a jug of coolant from them to be safe.
Jeff
Old Feb 11, 2007 | 04:55 PM
techbod's Avatar
the coolant is a mixture of antifreeze so dosnt count when topping up, G12 red is the norm but I would recommend topping up with water to see if the light goes out then consider doing a coolant change if required
Old Feb 11, 2007 | 05:06 PM
RHarris567's Avatar
Thank you both for your help. Does the coolant definitely need to be CHANGED? Or just added to bring the level up??
Old Feb 11, 2007 | 05:09 PM
techbod's Avatar
just add water to see if the warning light comes on and then decide if a coolant needs a change, go into a garage and ask them to test the coolant viscosity they have the tools and should do it free
Old Feb 11, 2007 | 05:24 PM
Ozz's Avatar
Ozz
Answeringyour question - "Prestone" is making thecollant that you can safely mix with Audi's original fluid, go to any Local Auto Zoneand ask there.
eddiefury
Nov 9, 2008 07:34 AM
bkcox_S4
Jul 3, 2008 01:56 PM
Armenian
Jun 22, 2007 06:29 PM
a4anonymous
Sep 26, 2005 06:56 PM
skull10
Jan 16, 2005 01:04 PM
