crank lock pin ...where does it go?????
I can't find where to put the crank lock pin. I have a 2003 A6 2.7.
The only thing I can see has a sensor wire coming out of it.
I thought it was supposed to be a plug with a bolt beside it to hold it in.
Anyway, can someone direct me to the HOLE...?
You remove the crank sensor and put it in there. Personally i never use it, i put on the cam lock bar then use some white out and mark the crank teeth in relation to the block. Much easier and works just as good.
vtraudt
Dec 20, 2012 06:02 PM
wtf01s4
Mar 20, 2009 01:17 AM
mr.eke
Jul 15, 2008 06:33 PM
