THIS IS CRAZY!!! WHATS WRONG WITH AUDI'S
Old Sep 1, 2007 | 03:56 PM
techbod's Avatar
Default RE: THIS IS CRAZY!!! WHATS WRONG WITH AUDI'S
[IMG]local://upfiles/12092/79098E51355B4CAEB8C15BF5710AEF3A.jpg[/IMG]
Old Sep 1, 2007 | 04:06 PM
techbod's Avatar
[IMG]local://upfiles/12092/F2AE3DC47E4B4F18B71533070E0B10BF.jpg[/IMG]
[IMG]local://upfiles/12092/E35D47C35691498CAAFC84961AC381C9.jpg[/IMG]
Old Sep 1, 2007 | 10:35 PM
jasmix's Avatar
I checked my belts and they seem fine and tight... not too much wearI guess... should I use Sea Foam?
what else could cause P0300 code.
Old Sep 2, 2007 | 02:47 AM
techbod's Avatar
I think your not seeing what the pictures are telling you ( low oil pressure ) this will effect the valves which are hydraulic and that throws the valve timing out hence the P0300 valves not doing their job,
edit: cylinder head oil pressure too low, CMP actuator sticking/defective
Old Sep 2, 2007 | 01:36 PM
jasmix's Avatar
hmmm...so should I clean or replace the camshaft position sensor? any link which shows how to replace/clean
Old Sep 2, 2007 | 03:06 PM
techbod's Avatar
dont clean just test or replace
Old Sep 2, 2007 | 03:09 PM
techbod's Avatar
if that dosnt solve it you have a serious oil pressure problem to the cylinder heads
Old Sep 2, 2007 | 03:35 PM
  #18
jasmix's Avatar
how to test?Im gonna order oneits like $40 bucks... but worst scenario if that doesnt help you mean to say my engine is screwed?
Old Sep 2, 2007 | 03:48 PM
  #19
techbod's Avatar
nope just the oil pump or a clogged oil vent to the cylinder heads but the CMP is suspect
Old Sep 2, 2007 | 04:20 PM
  #20
mach1usmc's Avatar
Aren't you supposed to replace your timing belt every 60k miles? .....or is this just on the 4.2's?
