THIS IS CRAZY!!! WHATS WRONG WITH AUDI'S
Old Sep 2, 2007 | 04:27 PM
  #21
auditech79's Avatar
Default RE: THIS IS CRAZY!!! WHATS WRONG WITH AUDI'S
ORIGINAL: mach1usmc
Aren't you supposed to replace your timing belt every 60k miles? .....or is this just on the 4.2's?
60 is a little early, every 80k is good practice. Audi calls for 105k but i think they changed it because they kept on buying cylinder heads for people from snapped timing belts.
Old Sep 2, 2007 | 09:32 PM
  #22
jasmix's Avatar
so how do you test CMP? I have a multi meter what Do i do
Old Sep 2, 2007 | 10:12 PM
  #23
Lilo Shark's Avatar
is lucas oil additives good? i put it in my audi a couples months back and after that i have i ticking in my engine?
Old Sep 3, 2007 | 02:28 AM
  #24
techbod's Avatar
ORIGINAL: jasmina
post #11 shows how to test it with the multimeter.
is Lucas oil additives good? i put it in my Audi a couples months back and after that i have i ticking in my engine?
I use slick 50 not sure if it is available over there as for Lucas they have a very good name and dont see any problem with it ( always read the instructions ),
http://images.google.co.uk/images?gb...ve&spell=1
Old Sep 5, 2007 | 03:50 PM
  #25
jasmix's Avatar
call me crazy I cant find it? I removed the cover but nothing ..do you have pic of the engine not the gif
Old Sep 5, 2007 | 04:53 PM
  #26
auditech79's Avatar
You can see them if you remove the timing covers, they are directly over each cam sprocket.
Old Sep 5, 2007 | 05:06 PM
  #27
jasmix's Avatar
Is this attached image right? I have opened the black plastic cover and I can see the Injectors wires etc. the timing cover is at the front but the image says the sensor is at the wall?
Old Sep 5, 2007 | 05:15 PM
  #28
auditech79's Avatar
Thats a 12V 2.8L engine, is that what you have? That's where it sould be on the 12V, on the 30V 2.8L they are on the front.
Old Sep 5, 2007 | 05:29 PM
  #29
jasmix's Avatar
Yes I have a 2.8 Quattro
Old Sep 5, 2007 | 05:36 PM
  #30
auditech79's Avatar
Nah, i mean there are two different 2.8L engines. One has 2 valves per cylinder and the other has 5v. The one in the picture has 2 valves per cylinder, is that what your motor looks like? The 30V 2.8L engine looks a lot different....... If you can't tell the difference go ahead and post a pic of your engine.
asalian
Sep 25, 2010 03:39 PM
missa4
May 5, 2008 11:31 AM
EliteTuning1
Jan 31, 2007 01:36 AM
1BADS4
Jul 17, 2006 11:47 AM
djkobra1
Apr 10, 2006 11:41 PM
