Cross Spoke Wheels
Old May 24, 2008 | 09:18 AM
tomz322's Avatar
Default Cross Spoke Wheels
I have the Audi 17" cross spoke factory wheels on my A6. The wheels have a centerpiece which covers the wheel bolts. I need to take the centerpiece off and I think that it unscrews, however, it is not easy to get a grip and do it by hand.
Is there a special tool, or does anyone have any suggestions on how to get the centerpiece off if it is on too tight? Thanks.
Old May 24, 2008 | 09:52 AM
TwinTurboC5's Avatar
Default RE: Cross Spoke Wheels
Hi. Is there a pinhole in the cap or a screw? If there is a pinhole, look in your tool kit located in the trunk and there is a small tool similar to a hook used to pull it off. If you don't have one, you can impovise and use a small allen key or some similar stiff piece of wire. If there's a screw head, just check and see what type of fastener is used to secure it in place....Hope this helps and Good Luck!
Old May 24, 2008 | 02:46 PM
WeezyTT's Avatar
Are you talking about the 17" BBS wheels? If so you are supposed to need a tool but if you know a friend thats a beast im sure he can unscrew it for you. It took me and my friend 45min to figure out how to get to the bolts and we never felt more retarded when we found out you just have to unscrew it. Get someone with a big hand.
rezron
Feb 20, 2009 01:03 PM
DerrickS
Nov 15, 2008 11:48 AM
studioc
Jun 8, 2008 03:46 PM
Penman
Aug 15, 2007 12:44 PM
FattieJayMack
Feb 19, 2007 06:30 PM
