2004 A6 headlamp removal
Old Sep 3, 2007 | 07:49 PM
jjo1695's Avatar
Default 2004 A6 headlamp removal
The passenger side headlamp just blew out. I'm trying to change it but can't get the headlamp unit out of the car. I removed the two torx screws on top of the unit but it seems to be held in at the bottom. Has anyone done this?
Old Sep 3, 2007 | 07:52 PM
auditech79's Avatar
Default RE: 2004 A6 headlamp removal
Gotta pull the bumper mate.
Old Sep 5, 2007 | 07:48 AM
bob martin's Avatar
There is a third torx screw down a hole in the radiator support. It's almost impossible to see. Do a search on replacing the Y-pipe and the write ups I have seen show how to tkae the headlight out.
Bob
Old Sep 6, 2007 | 04:25 PM
dmayer75's Avatar
pull the bumper??? you don't have to pull the whole headlight out to replace the bulb. just pop off the cover on the back of the light and untwist the collar that holds the bulb in place. put a new bulb in and be done with it. just don't touch the new bulb with your exposed skin.
Old Sep 6, 2007 | 10:06 PM
auditech79's Avatar
ORIGINAL: dmayer75
Well i was just stating in order to get the headlamp assembly out without breaking it you have to remove the bumper cover. Its possible to get the headlamp assembly out without taking off the bumper but you can break part of the lower headlamp assembly, and that is just stupid to try.
Old Sep 6, 2007 | 11:29 PM
dmayer75's Avatar
maybe the 02 a6 is different, but i pulled out my whole headlight assembly to replace a bad ballast and it was no problem. bumper stayed put and nothing broke. and i was just stating that you don't have to pull the headlight out to replace the bulb.
Old Dec 1, 2007 | 06:40 PM
ek1180's Avatar
I have A4 and should it be the same way. It is a really tight space, and I don't think that I can get the bulb out and the new one in. Do you have any suggestions?
Old Dec 1, 2007 | 06:49 PM
dankhound's Avatar
On the a4 you dont have to removed the bumper to get the headlight out. You just have to remove the two bolts on top of the headlight and loosen the two on the bottom. You can also remove the airbox or the ps reservoir to give yourself more room if you dont want to removed the headlight assembly.
Old May 24, 2008 | 03:50 PM
benormous's Avatar
for the record, I removed the headlight assembly today and I didn't have to take the bumper off. I didn't even need a Torx to take out the '3rd' bolt. I just used a long and narrow flat head screw driver. And this was on a 2000 A6
Policemanjim
May 6, 2013 10:42 AM
Bayjammer
Feb 27, 2012 04:24 PM
///MPower
Nov 9, 2008 10:21 PM
Devastata_A6
Sep 27, 2006 09:36 PM
elewsader
Mar 7, 2006 12:18 AM
