CV joint / axle replacement
Old Jan 21, 2008 | 12:50 PM
TuHandy's Avatar
Default CV joint / axle replacement
Hello,
Yes Newbie to Audi forum. I will make it short.
I need to replace both front outer cv joints on myquattro and am not sure if I should replace the whole axle shaft assemblies or justthe cv joints. And where is the best/cheapest place to buy either.
Thank you for your comments.
Old Jan 21, 2008 | 04:07 PM
NH_USA's Avatar
Default RE: CV joint / axle replacement
Get rebuilt axles assemblies. (AutoZone among others have them) Outer CV joint by them selves run around $125 and then you have to install them on the axle.A rebuilt axle runs about $135, takes less time to install, andyou get all new boots.
Don't believe the guys that tell you it can be done without popping the lower ball joint. It can be done but you have to hammer the crap out of it and takea chance of hurting other things.
Old Jan 21, 2008 | 09:53 PM
WolfsA62.8Q's Avatar
Listen to NH_USA, rebuilt axle assemblies is the way to go, they are quick and should have a warranty. I had my axle shipped from PA, forget the name, but found them on the web.
Old Jan 21, 2008 | 10:36 PM
99A6Q's Avatar
Get all new shafts. The price is virtually the same and you are getting all new boots plus new inners cvs also
Old Jan 21, 2008 | 11:42 PM
TuHandy's Avatar
Thanks for the replies.
I have found exactly what your saying. The price of the axle joint is about the same price as a new/rebuilt complete axle. I have tried the local autozone, but said they can not get it. I will try again.
Thanks again.
biocpu
Feb 13, 2012 04:28 PM
bhollehday
Nov 15, 2011 11:23 AM
Audilaw
Oct 14, 2010 06:11 PM
apalmer
Oct 29, 2007 12:10 PM
AUDIA642
Oct 24, 2007 01:44 PM
