DASH PROBLEMS (KM)
Old Jun 21, 2005 | 01:41 PM
vivastar's Avatar
Default DASH PROBLEMS (KM)
hello there can somebody help i do have AUDI A6 1998 model,i have a problem on the dash screen when i drive it at 20 km/h is starting showing on the dash KM light and the beep is starting ,i dont know how to fix this problem ,pleease of anyone knows or had this problem on the past .URGENT BEKIM
Old Jun 21, 2005 | 02:19 PM
FootIntheGrille's Avatar
Default RE: DASH PROBLEMS (KM)
Are you sure that the speed limit warning system did not get accidentally activated? The A6 has a system that you can set the speed that if exceeded it will beep and warn you that the preset speed has been exceeded. The manual will tell you hot to clear the speed setting. The happens to a friend with her car all the time... she accidentally bumps the button that engages the system.
Old Jun 21, 2005 | 03:23 PM
vivastar's Avatar
Well i dont have a manual that is the problem like i said i checked with WINELSA but didnt give me nothing regarding to the this ,
well do i have to adjust it with vag-com and on which channel or is there anyway else.THANKS
Old Jun 21, 2005 | 05:39 PM
I will have to look in the manual tonight. I never use the feature so I am unsure. Its pretty simple, something to do with the lever and buttons on the right side of the steering column.
Old Jun 21, 2005 | 06:01 PM
jukeit's Avatar
I accidentally activated mine. To activate it I get up to the desired speed, then hold in the tripometer juke for a few seconds. That activates it. Can't remember how I deactivated it. I think I just hit the tripometer thinger again when the speed sensor alarmed.
Old Jun 21, 2005 | 10:29 PM
rs's Avatar
rs
either that or i think when u flick thru the screens on the wiper arm, has the button that u can click up or down, to move thru screens, think that mite deactivate it, not sure tho
Old Jun 22, 2005 | 08:19 AM
vivastar's Avatar
thanks thanks a lot guys very kind of you all for help ,i am going to try today and to work out on this i hope it will get fixed,the problem is that NOBODY until now didn`t fix it so i will check it today.
I WILL LET YOU KNOW GUYS HOW I FIX IT OR IF THIS DONT WORK I WILL TAKE A PIC OF IT AND SHOW IT .
BEKIM
Old Jun 22, 2005 | 11:56 AM
I brought the manual for the car. This manual is for a '99 A6 (mines an '00 , but the manual I got with it is in French) I need to type in the directions, onless I can scan the pages. Will post later today.
Anyone know if the 99 dash is the same as the 98?
Old Jun 22, 2005 | 12:22 PM
stilon's Avatar
As far as I can tell, yes. I have a 99 but my manual is for 98 and it all looks the same.
Old Jun 22, 2005 | 03:14 PM
vivastar's Avatar
Default DASH PROBLEMS (KM)THANKS
THANKS THANKS THANKS A LOT GUYS I MADE IT I DEACTIVATED WITH TRIPOMETER.
I DONT KNOW HOW TO APRECIATE THIS HELP.
but in case on the future on you can need something from WINELSA any code or anything which you get it with VAG-COM i do posses this programs i will do my best ,also if you need VAG-COM i can send it over to you guys on EMail.
THANKS AGAIN PROBLEM SOLVED
99A6er
Mar 24, 2009 08:37 AM
vivastar
Jun 29, 2005 10:58 AM
FootIntheGrille
May 20, 2005 11:03 PM
Jayhawk86
Sep 13, 2004 03:03 AM
Jayhawk86
Jul 11, 2004 11:36 AM
