Desperately need help...2001 A6
Old Jan 13, 2010 | 11:14 AM
cjm32's Avatar
Default Desperately need help...2001 A6
I bought my A6 2.8Q in July with 97,000 miles (now has 107). I got it for a steal at $6,700 (what they paid for trade in - was listed at $12,900) because I've known the dealer's son for years. Here's the problem I am encountering:
When I start the car in the morning it starts up perfectly fine. One turn-over and it is good to go (this morning being the lone exception taking about 2 seconds). When I shut the car off, as long as I start it within about 5 minutes it starts up right away. However, after anywhere from 10 minutes to 4 hours later it will take 6-8 seconds to start. During this time when it starts up the rpm's will idle at 200 for a second, then jump up to 400 for a second, then to 600 for a second before permenately idling around 800. This indicated to me that there was a fuel problem, likely pressure related.
Here are the repairs I have done thus far - mostly time change items (totaling $1,400):
August - Fuel Pump & Fuel Filter
September - Coil Pack (all 6)
November - Timing Belt, Serp Belt, Water Pump & Spark Plugs
December - Battery & Vaccum Hoses
January - Fuel Pressure Regulator (prior to replacing this it could take as long as 15 seconds to start).
There are two other things I have noticed - one is that it doesn't have the punch it used to when driving it. Second, I do have a CEL that came on two weeks ago indicating a faulty Coolant Temp Sensor which I will be replacing shortly.
Any ideas on where to go from here?
Old Jan 13, 2010 | 11:45 PM
Jeffla's Avatar
umm, replace your coolant temp sensor. Then go from there, but I bet all will be better.
Old Jan 13, 2010 | 11:46 PM
Jeffla's Avatar
ooops
Old Jan 14, 2010 | 12:16 AM
cjm32's Avatar
That's what I am hoping for. The concern is that it was occurring before the CLE came on. Although it may have been two sources causing it (the FPR & CTS). Would the CTS account for a sluggish acceleration as well?
Old Jan 14, 2010 | 09:42 AM
bob martin's Avatar
Yes, it would. The ECU will replace the actual temperature value with its best guess, which will be consevative to keep the engine from self-destructing, leading to reduced performance.
Good luck,
Bob
Old Jan 14, 2010 | 11:06 AM
cjm32's Avatar
I should mention that the code is now P1296 instead of P0118...I am still planning to replace the CTS. Is this the correct solution?
Casey1330
Jun 4, 2013 08:17 PM
metalmmaniac
Aug 1, 2008 12:43 AM
ILoveT
Jul 7, 2007 07:05 AM
htk813
Aug 12, 2005 07:23 PM
