different flavors of chips?
Old Jan 3, 2008 | 07:23 PM
liquidcolombian's Avatar
Default different flavors of chips?
Just wondering if there is anything wrong with using the GIAC tipchip and also having the APR ecu upgrade?? this may be a dumb question sorry
Old Jan 4, 2008 | 06:23 PM
Default RE: different flavors of chips?
just wondering if using two different brands of chips is bad?
Old Jan 6, 2008 | 10:12 AM
joetm's Avatar
I have the GIAC tip chip and also the GIAC race fuel ecu program... I am not sure it is bad to go with 2 different manufacturers but typically things that are manufactured from the same company are more likely to be compatible as the company tests the different components together and makes sure they do in fact "mesh" or work together
Hope that helps
Old Jan 7, 2008 | 08:03 PM
joetm's Avatar
hey i was wondering and just remembered ... when you got the giac tipchip did you load it on yourself or did someone else do it for you because i loaded mine a while ago and they are in teh process of upgrading software because it came with issues as im experiencing now ... if you had it loaded please let me know where you had it loaded or where you got updated software from giac
thanks
LeM0N
Apr 23, 2008 10:37 PM
AdiInAnAudi
Apr 19, 2008 11:09 PM
daridari
Jun 26, 2007 07:46 AM
cary12
Mar 19, 2006 02:01 PM
kourosH
Mar 8, 2005 01:30 AM
