differential
Old Jan 11, 2010 | 01:00 PM
achase1's Avatar
Default differential
the shop told me my differential is bad.....what is the cost for a new one?
audi a6 2000 2.8L
Old Jan 11, 2010 | 02:19 PM
achase1's Avatar
the car is making a high pitched whirring noise which gets louder as it shifts into gear but dies down when it is cruising in that gear
Old Jan 11, 2010 | 11:12 PM
NH_USA's Avatar
Ask Force five in Concord NH about a used one!
Old Jan 12, 2010 | 05:46 PM
bob martin's Avatar
Front, center or rear?
Bob
Old Jan 12, 2010 | 07:42 PM
a6hcw's Avatar
Have you tried draining the old differential gear lube and replacing it with new synthetic gear lube?
Old Jan 13, 2010 | 01:12 PM
bob martin's Avatar
If a diff is making noise that you can hear clearly in the cabin, it is shot. Or, at least, the bearings are. Unless you have a mechanical limited slip, which we don't. Or, unless you have a racing gear set, which we don't.
In any case, it needs to be taken to a skilled Audi mechanic. Getting the preload and backlash set up correctly for quiet operation is not an easy task.
Bob
Old Jan 14, 2010 | 11:06 AM
achase1's Avatar
bob,
i am in puerto rico which is a difficult place to find a skilled audi mechanic. they are recommending that i replace the whole transmission which they think will be less costly for me to do. i am thinking about a refurbished one. will keep you updated. thanks for the advice.
Old Jan 18, 2010 | 12:35 PM
achase1's Avatar
i originally took my audi in because the tcm was shot, the mechanic reprogrammed it, i am guessing he just downloaded new software. at the same time he changed the trans fluid and filter. well the tcm is still acting up and as soon as i got the car back it was making a new sound, a high pitched whining in idle which gets louder as it moves into a new gear. the mechanic told me it is the differential which is bad. is it possible he could have damaged it by changing the trans fluid? i'm confused because it wasn't making the sound before i took the car in. i'm taking it to a new shop thur. and will let you know.
thanks for all the advice - andy
Old Jan 18, 2010 | 12:38 PM
achase1's Avatar
read my latest thread and please advise - thanks!
hank1995
Mar 20, 2007 03:30 PM
225tt
Jan 22, 2007 07:05 PM
98 1.8 quattro
Nov 30, 2006 11:02 AM
STEVE36
Mar 12, 2006 07:55 PM
topgod6
Feb 28, 2006 01:51 AM
