Door sensor problem
Old Aug 27, 2010 | 08:41 PM
Theiceman's Avatar
Default Door sensor problem
How does the A6 know the door is open ? is it in the latch assembly as i can find no plunger switch . The reason I ask is I just noticed the car i recently purchased does not inicate when the key is in the ignition when i open the door or give an alarm if the drivers door is open . is this normal ?
Theiceman's Avatar
BTW i have an 00 A6
Old Aug 28, 2010 | 12:12 AM
Jeffla's Avatar
more than likely your drivers door latch is bad. It is very common for them to fail as they get older. Changing it takes about 1 hour.
http://forums.audiworld.com/showthread.php?p=15013077
This is a link to a guy who instead of replacing the door latch, he fixed it. I just bought a used one, but his directions were useful non the less.
Old Aug 28, 2010 | 09:20 AM
Theiceman's Avatar
hey that's a great link thanks .. I think i 'll go the fix it route ,,, after all if your gonna replace it anyway what do oyu have to lose ?
Thanks again
Old Aug 28, 2010 | 11:52 AM
Jeffla's Avatar
Time
I was gonna go the fix it route, but then I just decided $75.00 dollars and I would be done with it. If it fails again, I will attempt to fix it myself. It looks rather easy, just time consuming.
Old Aug 28, 2010 | 02:29 PM
Theiceman's Avatar
don't think i will get it for 75.00 in canada .. besides ,, it's all in the challenge ..
contherad
Feb 17, 2012 10:08 AM
MyA4Mobs
Feb 19, 2011 04:08 PM
lumend13
Nov 16, 2008 09:30 AM
erike1
May 4, 2008 10:25 PM
domenicostorino
Apr 24, 2008 04:01 AM
