Driver side mirror
Old Dec 11, 2007 | 01:35 PM
cdpoppert's Avatar
Default Driver side mirror
My driver side mirror glass was stolen but I am not quite sure what all needs to be replaced as I have never seen behind the glass before so not sure what it is supposed to look like.
To me it looks like someone just popped the glass off and unplugged three wire harnesses. All of the mechanicals are still in tact.
Wondering if someone has advice as to this happening to them or how I might be able to tell what all I need to replace and the best place to buy the part or parts.
Old Dec 11, 2007 | 01:40 PM
AZAudiA6Q's Avatar
Default RE: Driver side mirror
Replace the whole mirror.
Old Dec 11, 2007 | 01:53 PM
maxims45's Avatar
Member
If plastic circle to is still there then you might replace only mirror part (costs $20-30)
Old Dec 12, 2007 | 12:59 PM
cdpoppert's Avatar
The plastic circle is still there. How does the mirror glass fasten to the circle and does the replacement mirror glass have connections to the 3 wire harnesses coming out of the mirror housing. What are those 3 wires for?
Old Dec 12, 2007 | 03:54 PM
maxims45's Avatar
Member
The picture is attached. The connector is for heated mirror.
[IMG]local://upfiles/45995/409365016E184C44A6A31793C75574E5.gif[/IMG]
Old Dec 12, 2007 | 04:03 PM
NH_USA's Avatar
There is a plastic ring attached to the back of the mirror that snaps into the ring in the housing.
When my mirrors get funky Iusually get a whole assembly from a junkyard and just swap the mirror portion.
BTW nice picture --Where did you get it?
Old Dec 13, 2007 | 02:45 AM
maxims45's Avatar
Member
I've got this printout picture from a shop with the mirror part (as guideline to install it). They said this image is from ELSA.
I know that it is illegal to copy images directly from ELSA. So should I remove it?
Old Dec 13, 2007 | 08:16 AM
NH_USA's Avatar
I also have ELSA and find ita good source when trying to figure out how something is put together but I had kinda forgotten about it.
Bentley is helpful but horrible when it comes to graphics.I questioned the source of the picture because itmade the construction very clear and wanted to know ifI was missing an opportunity to get more info when I began a project.
Old Dec 13, 2007 | 08:35 AM
maxims45's Avatar
Member
yes, that was elsa - I've found the same picture there. The only trouble was to install elsa on vista - it fails while opening workshop. I've installed XP under MS Virtual PC and it works there now.
Replacing mirror part also helps if heating fails - mine mirror was not heated before replacing the element.
Old Dec 13, 2007 | 09:18 AM
NH_USA's Avatar
ORIGINAL: maxims45
Another reason to tell Mr. Gates and company where to put Vista!
I hope XP is the last upgrade I need to do. Got XP pro on my Puter and had a few minor problems. Got XP pro with my wife's laptop and everything was great. Got Vista on mydaughter's laptop andhad nothing but trouble. Thank's Billy Boy...
peterko1
Feb 20, 2015 04:23 PM
trickster00a6
Oct 19, 2009 06:10 PM
tripvanwinkle
Mar 18, 2009 12:09 PM
BITRBO
Feb 17, 2009 02:11 PM
maxxstl
Jan 14, 2008 06:04 PM
