Fuel Induction Service
Old Dec 12, 2007 | 11:33 AM
Teutonic2.7T's Avatar
Default Fuel Induction Service
whaddu know about it? is it necessary? during what intervals? is it something i should do with the dealer?
discuss... discuss!
Old Dec 12, 2007 | 02:48 PM
Default RE: Fuel Induction Service
friends, ur advice please... im a young guy.. on second car...still figuring sh*t out...
work-with-me.
Old Dec 12, 2007 | 03:46 PM
NH_USA's Avatar
I haven't a clue as to what your talking about unless it is the fuel injectors.
The only thing to watch out for is injector plugging. A can of injector cleaner in the gas once in a while and changing the fuel filter every year or so is all I have ever done. It seems to work cause I got 350K on one Audi, 180K (and still going) on another, and 140K (still going) on another.
Old Dec 12, 2007 | 03:50 PM
im sorry i should but this down on my file... i went to the shop 2day for my VW Passat and they recommended that i get a "Fuel Induction Service" which blows out all of the carbon etc accumulated in the car. i figure its something i should do on my 2.7T.
below is a DIY from audiworld forums.
http://forums.audiworld.com/a6100/msgs/73585.phtml
let me know what you guys think.
Old Dec 12, 2007 | 03:57 PM
NH_USA's Avatar
That is a typical shop add on to get you to spend $$$$$ on a sounds good scheme.
A can of injector cleaner will do the same thing but take a bit longer. Just add it to a full tank of gas and drive. If things are real dirty do it a couple times - every other tankfull. Other wise don't waste your money... If you really- really- really want to spend money send it to me!
Old Dec 13, 2007 | 12:27 PM
nemohm's Avatar
I'd suggest
Lubro-Moly
LM2001 - VALVE CLEAN
LM2007 - JECTRON
LM2030 - PRO-LINE FUEL SYSTEM CLEANER
LM2031 - PRO-LINE FUEL SYSTEM CLEANER CONCENTRATE
VALVE CLEAN, JECTRON work well with 1 gallon of fuel (commercial purge).
There is a lot of info on the net.
Unless you give it a try you will not know how much difference will get.
Keep in mind there are two areas of cleening: injectors and valves/combustion chambers.
websterz2002
Apr 16, 2011 04:36 PM
44flan44
Apr 27, 2008 02:02 PM
j_ripper19
Sep 11, 2006 06:02 PM
mikepangko
Apr 9, 2006 02:17 PM
juice88
Aug 17, 2005 07:11 AM
