Sponsored by:
Sponsored by:
drives in park and neutral
Old 07-18-2012, 02:18 AM
Sammy~D's Avatar
Default drives in park and neutral
I replaced the tcm in my 01 a6 2.7t tiptronic because of other issues it worked great for 3 blocks then went back into limp mode no reverse and now it trys to drive in park or neutral im at wits end. Any ideas
Old 07-18-2012, 01:08 PM
eazy211187's Avatar
So replaced with another one and then it kicks you in limp mode after 3 blocks.
Check the connectors and wiring going to TCM for breaks, cuts or corrosion.
If none are found then try resetting the faults with vag com
The TCM sent a signal to the ECU and the ECU trigger limp mode.
So swapping the TCM will fix the problem but you still need to clear the codes.
If that didn't fix the issue take it to a indie shop.
Old 07-18-2012, 01:41 PM
Sammy~D's Avatar
But would that make it not have reverse?
Old 07-18-2012, 02:00 PM
Sammy~D's Avatar
When i put it in reverse today it went in but wont move and revs out at 2k-2.5k it almost feels like parking brake is on
Old 07-18-2012, 04:14 PM
budhani786's Avatar
Maybe be reverse drum is broke? It's a common failure on this tranny.
Old 07-18-2012, 08:49 PM
Jeffla's Avatar
When will your vag-com cable arrive?
Old 07-19-2012, 03:58 AM
Sammy~D's Avatar
No idea has not even shipped yet i dont think
Old 07-21-2012, 12:37 AM
Jeffla's Avatar
I work in coon rapids until 10pm this Saturday (tomorrow). If you want, I can stop by after work and pull your codes. I can't stay long. PM me your phone number and address and I'll bring my laptop and vag-con to work with me in case you take me up on my offer. I saw your post on mnaudi, not the friendliest bunch of over there.
Old 07-21-2012, 07:51 PM
Sammy~D's Avatar
I noticed that and pm is sending
Old 07-21-2012, 08:48 PM
Jeffla's Avatar
I'll call when I'm done at 10. Don't know how to reply to a pm from my phone
Jeff
Quick Reply: drives in park and neutral
