To DV or not to DV, that is the quest,,,
Ok, ive been hearing alot of things from diff audi owners, and i want to get the final opinion from you guys,,,
I have a 2.7t A6, was thinking of replacing my OEM dv's with HyperBoost HX Compact Anodized Diverter Valve, or just another type of DV,,,
Acouple of people told me that i should just stick with the OEM till/if they fail, and is they do, just stick with OEM one,,,
While other are telling me that the OEM leak and rob you boost and its better to replace them,,,
not even thinking of BOV, cause Audi's re-circulated the air, and not just release into the atmosphere, (basically not good),,, So what you guys think???
Also,,,any real point on changing the stock intake, heard its good till 350hp, and no point to change,,,and if so which to go with (rem the 2.7 intake are near the left turbo, so would need the box, or a good heat shield)
Thanks,,,
Thanks,,,
