:: ECS Tuning :: C6 A6 3.0T & 4.2L Geomet® Brake Rotors
Old May 23, 2014 | 03:59 PM
ECS Tuning's Avatar
Sponsor
Default :: ECS Tuning :: C6 A6 3.0T & 4.2L Geomet® Brake Rotors
ECS GEOMET® premium brake rotors start with quality materials and precision ECS machining. That would be enough for most of us, but it is only the beginning.
To prevent brake pad deposits for better braking, select a slotted and dimpled ECS GEOMET® rotor. Slotting cleans the pads by moving water, gasses, and contaminants away from the pad/rotor contact surface.
To prevent rust pitting and corrosion damage, ECS GEOMET® rotors are sprayed with a special water-based solution, then heated to cure the coating and remove all oil residue remaining from the manufacturing process.
Prevent Corrosion Damage.
Click HERE to order for more information
Fits:
Audi C6 A6 3.0T/4.2L (2005-2011)
Let me know if you have any questions.
Jason
ECS Tuning
S5
Mar 19, 2015 11:16 AM
ECS Tuning
S4
Mar 2, 2015 12:10 PM
ECS Tuning
B8 Models
Feb 23, 2015 04:08 PM
ECS Tuning
S4
Nov 21, 2014 10:57 AM
