Eliminating Check Engine Light Please Read
Old Jul 14, 2008 | 03:22 PM
2000_2.7t's Avatar
Default Eliminating Check Engine Light Please Read
Does anyone know how to disable/break/turn off check engine lights in audi a6's?I just simply want it to go away. Thanks in advance.
Old Jul 14, 2008 | 03:37 PM
techbod's Avatar
Default RE: Eliminating Check Engine Light Please Read
you cant disable it
you can break the bulb
you can fix it with a diagnostic test and find out what the problem is that way at least you will have a fault code to assist on the repair
Old Jul 14, 2008 | 05:05 PM
hxgaser's Avatar
Why would you want to disable it, unless you want to see smoke coming from the car? Possibly a loud explosion?
Old Jul 14, 2008 | 06:28 PM
xpl0sive's Avatar
because he probably just wants to sell his car without fixing the problem and ******* over the next owner...
Old Jul 14, 2008 | 11:14 PM
formulagigi's Avatar
^ I hope not!!!! I hate those guys...
YOU got to find out why you have a cell by getting it VAGged, ONce you have the codes, post them and see if someone can help. Resolve the issue and it'll go away. Even if you cleared the code, changes areit'll come back if youdon't fix the underlying issue,Or take it to a shop.
Old Jul 15, 2008 | 07:59 AM
massboykie's Avatar
Member
ORIGINAL: xpl0sive
Yeah...
Cheers
Massboykie
Old Mar 28, 2016 | 01:55 PM
neto2212's Avatar
Default 2008 audi a4 Quattro, p0299 loss of turbo
Check engine light turns on and it says loss of passage to turbo and i found a leak in the car is that possibly the solution to making it go away? .the leak is uder the transmission very hard to see but it is a broken plastic i believe where some pumps connect.
Old Mar 30, 2016 | 10:02 PM
ppgoal's Avatar
I have a CEL from bad cats, even after I replaced them. Fixed it with a 1"x1" piece of black electrical tape over the icon. It will drive you nuts when you sit in the passenger seat and see it again. :-)
Old Mar 19, 2019 | 11:51 AM
dbx's Avatar
dbx
sounds about right, can't think of any other reason why somebody would want to disable the CEL.
Itsheraudi
Jul 23, 2009 02:53 PM
ooTToo
Jul 9, 2008 01:03 AM
sntemp
Jun 5, 2006 05:41 PM
Sichko
Jan 8, 2006 12:51 AM
a4ddt
Sep 27, 2005 02:01 AM
