Emergency Brake (E-Brake) Light Blinking when engine on
Old Jul 20, 2008 | 03:36 PM
fidelite's Avatar
Default Emergency Brake (E-Brake) Light Blinking when engine on
History:
I had my brake light go off about a month ago, as a result I replaced the front pads and rotors. The rear brakes were in very bad shape at that point, but I didn't have the resources to take care of it. After the front brake replacement the stupid yellow light went out, and all was well. I noticed that the front brakes were dusting quite badly, so I decided to get the back brakes done.
Issue:
Yesterday I got the rear pads and rotors replaced, during the replacement the mech forgot to open the resivoir at first, and after he tried to push the cylinder back, he opened the resivour and continued the repair. After the repair the car beeped and then the parking brake light flashed.
Troubleshooting:
- I've checked the fluid levels, they appear to be fine
- The manual seems to indicate that if the light is on after the engine is engaged the fluids may be low, but it does not mention anything about the light blinking.
- I've googled, some people think that it might be the slave cylinder, the ABS sensor, and something about the piston being extended to the max as a result of me waiting too long to replace the rear brakes, and I've read that it takes some time to break in the brakes and the film may be tripping out some kind of sensor.
- I've engaged the parking brake, at this point the light stops flashing and goes solid, if I bring it back down, the light begins to flash again
Suggestions to troubleshoot this further
Old Jul 21, 2008 | 06:44 AM
fidelite's Avatar
Default RE: Emergency Brake (E-Brake) Light Blinking when engine on
Temporary Solution:
Black electrical tape over the stupid blinking light so I don't constantly look down and think my turning signal is on.
Old Jan 28, 2009 | 09:00 PM
T_W's Avatar
T_W
Same problem. Did you ever find a solution that did not involve electrical tape?
Old Jan 29, 2009 | 06:50 AM
bob martin's Avatar
Try operating the e-brake about 20 times to get the handle tighter.
Bob
Old Feb 3, 2009 | 11:04 PM
T_W's Avatar
T_W
According to dealer, emergency brake cable was frozen and had to be replaced.
HJ Matroni
May 11, 2013 10:45 AM
.clipse
Nov 16, 2008 04:58 AM
moeron7
Jan 22, 2007 03:16 AM
99a4
Sep 8, 2005 03:01 AM
