Engine oil - synthetic or conventional?
I got my 50k service done at the Audi dealer yesterday and I was looking over my receipt and the part number for the engine oil that they put it in my car is: ZVP-000-300. I did a quick search online and now I am not sure that this oil is synthetic. I was charged $3.10 per quart and they used 7 quarts. Isn't that price a little too cheap for synthetic oil at a dealer?
Assuming that it was conventional oil, will there by any side effects if I put in synthetic oil the next time around? Are there any precautions to be taken (like a flush with synthetic, maybe?) before I start using synthetic motor oil? Does conventional and synthetic oil mix?
Thanks!
Thanks!
This is a soap-box issue for me, but I'll try and remain calm. For the record, most so-called synthetics come from crude just like conventional oils.
That said,syntheticsare completely compatable with conventional motor oils and no precautions are necessary for the change over. Just drain and fill.
No side effects from using conventional oil. It's just not something you want to keep using due to engine build up. No big deal, just bring your own oil and filter next time around.
Maybe someone can clear this up for me, I forget which does which, but I had heard either synthetic or conventional oil makes your seals swell more than the other, so if you switch theywill shrink and cause small leaks. Any truth to this?
I can't say it is a non-issue, but the chances of this happening now are very slim. Synthetics are now formulated with seal swell agents to keep seals in good shape.
Ive never had a problem with synthetic oil even on high mile older cars as long as the right weight is used and that's why there are 2 categories of synthetic ( full and semi ) full is used on the newer cars and semi on the older ones but synthetic is without doubt the better choice and its proven
Synthetics also resist heat better than conventional oils, for this reason I would use only synthetics in turbocharged cars.
Be aware there are three classes of base oils which can legally be called synthetic; Group III, Group IV, and Group V. Group III base oils come from crude and are far less expensive than Gp IV or Gp V, alsothey may not offer the same benefits. In the end however, one can formulate a fine oil with any of these base oils.
