Engine stalls
Old Jan 19, 2005 | 12:47 PM
anwa1505's Avatar
Default Engine stalls
Hi
Car is 99 A6 2.8Q Auto/Tip
Idles at around 600 - is this normal?
The engine will stall and car has to be restarted. Have to wait a few minutes to start the car as it will not start straight away following the cut.
Dealer had a diagnostic on it and it pointed to the Coolant Temparature Sensor being faulty. Had this replaced and car still idles low but has not yet cut-out again.
I have also had the belt changed recently and problem only happened following this. A tech mentioned that the timing may be out - is this possible? Could this cause the cut?
All help greatly appreciated.
Old Jan 19, 2005 | 02:16 PM
PaulA4's Avatar
Default RE: Engine stalls
Timing is set via the ECU so shouldn't be out, i'd look at the Idle control valve, not sure how it works on the 2.8 but i'm sure somebody else will.
Old Jan 19, 2005 | 03:32 PM
Jestnomen's Avatar
6th Gear
The 30 Valve 2.8 does not have an idle control valve.
Old Jan 26, 2005 | 09:08 AM
anwa1505's Avatar
Hi
Still at a loss here. Engine start on cold is fine. When car reaches normal operating temperature, the idle dips to around 500rpm. If I switch the car off and try to restart, it starts - revs shoot up to around 2000rmp for about 10seconds then dip to around 1000rpm. Move the shift to drive and the car stalls!
Any info really appreciated as the UK dealers are a rip.
Thanks
Old Jan 13, 2006 | 03:01 AM
sataie's Avatar
i'm having the same problem on my 99 A6 2.8Q.
it idles at about 500-600. used VAG to increase the RPMto the maximum setting, it is still at under 600RPM.
when the car is in 'Drive', the RPM drops to below 400, and dies when you cometo a stop. I have to drive with one foot on gas and one on brake.
is there any way I can manually increase the RPM???? thanks
Luke-Br
Sep 27, 2014 10:36 AM
njcupido
Oct 9, 2013 06:14 AM
mikestt
Sep 24, 2011 10:25 PM
heini
Feb 24, 2007 01:30 AM
Max A6 95
Apr 3, 2005 03:27 AM
