Engine Swap- Nearly complete but Wont Crank At ALL, & Fuel Pump isn't priming. Ideas?
Old Jun 14, 2014 | 01:10 AM
TheDood.'s Avatar
Default Engine Swap- Nearly complete but Wont Crank At ALL, & Fuel Pump isn't priming. Ideas?
Okay, long story short- Bought a 2001 Allroad 2.7t as a project. Car wouldn't run, would try to run some but was terrible.. PO told me something vacuum issues, acted ignorant, low and behold it had jumped time and was mashing up one cylinder without mercy. I found a drop engine with turbos for cheaper than I was estimating rebuild.
Now I've got the engine in, everything I can see obviously to do done..
I put a battery in today and was planning on seeing how bad the fuel looked from sitting after changing the Fuel filter, but it Will Not Prime. (assuming it primes when you first turn the key all the way before cranking like my b6 1.8t) and it will not crank at all..
I'm getting a check engine and an EPC light. Im not very familiar with VAG com and I have a Mac.
At first turn- I did forget that I had pulled a lot of relays to see if they'd swap into one I was testing.. So duh- thats the cause. Well I plugged em all in and still nothing, so I let it set with the battery disconnected for 5 mins and tried again without change..
I thought this might have caused some funk, so I unplugged the ECU before I left..
Otherwise- Any other ideas what would cause it not to try to crank or fuel pump to prime? Of course I'll look at my wire harness to see if I missed anything that would involve it.
*** I didn't have a couple things hooked up that I did not consider essential to the fuel pump turning on- Coolant tank, the trans (Tiptronic) is bone dry, I originally tried without the front clip harness but have since plugged it in. Not sure if this stuff is relevant but I thought I should mention
Thanks-
Peteyac
Aug 2, 2015 11:22 AM
wreksta
Feb 17, 2015 05:06 AM
Big_Jerm_210
Jun 25, 2014 03:39 AM
jam511
Jan 21, 2011 12:58 PM
transit360
Dec 23, 2008 04:53 PM
