Engine Swap Question
Old Jan 18, 2005 | 06:52 PM
Ocnaj's Avatar
Default Engine Swap Question
I just bought a 1996 A6Q wagon and the 2.8L just died on me with 275k on it. Is it possible to replace the 2.8 with a 2.7T? Thanx
Old Jan 18, 2005 | 07:21 PM
Jestnomen's Avatar
6th Gear
Default RE: Engine Swap Question
Sure anything is possible. The question is, can you afford it? It is not a direct swap. Much work would need to be done. All the electronics would have to be swapped out.
Old Jan 18, 2005 | 08:13 PM
Ocnaj's Avatar
How much work would it be just to get the engine in there?
Old Jan 18, 2005 | 09:33 PM
David_K's Avatar
try it sand tell us
Old Jan 19, 2005 | 12:39 AM
Jestnomen's Avatar
6th Gear
I dunno, everyone who tries an engine swap with an Audi always gives up after they research the costs of doing so. All of the electronics of the 2.7t are completely different (Can bus data line) than the 2.8. This means you would have to swap everything from the instrument cluster to the climate control. You would easily spend more time and money than the $5k your car is worth.
Old Jan 20, 2005 | 12:56 AM
wh22366's Avatar
If your rig was a '98 or later A6, you could do the deed if you bought a wrecked (rear-ended) 2.7 and patiently swapped in everthing that's unique to the 2.7. I've done this kind of thing in the past with pre-emission cars, but it was never really worth the effort. I thought about replacing the tiptronic in my '99 with a six-speed and quicky came to the conclusion it's a lot easier to swap cars. ]
Old Jan 25, 2005 | 01:57 AM
hobart's Avatar
If you want a cheaper better alternative there is a 2.8 supercharger kit that is GOOOOD about $2k gives 2.7+ performance. Do this on a good/ dynamic balanced REBUILT 2.8 and U will rock. European Car did a road test in 2003 on this mod.
Old Jan 25, 2005 | 09:45 AM
Jestnomen's Avatar
6th Gear
There is no supercharger for the 12 valve engine. Only the 1998 30 valve engine.
bmoore98A4
Jun 3, 2011 04:03 PM
twoeightquattro
Nov 23, 2010 07:06 PM
sjcarton
Jul 26, 2010 12:42 PM
JKEITH81
Aug 29, 2007 04:26 PM
SILVER_B5S4
Feb 6, 2006 07:51 PM
