Error code 421
Old Jul 1, 2008 | 11:37 AM
shaikha's Avatar
Default Error code 421
I just purchased 2003 Audi Avant A6 3.0, I got an error code of 421, which means low temperature catalytic flow. Could someone please help me understand this code. Any help would be appriciated. TIA,
Old Jul 1, 2008 | 11:41 AM
Jeffla's Avatar
Default RE: Error code 421
http://www.obd-codes.com/p0421
How many miles are on your car?
Old Jul 1, 2008 | 11:43 AM
shaikha's Avatar
105,200
Old Jul 1, 2008 | 11:52 AM
Jeffla's Avatar
If you DIY then clear the code and see if it comes back.
Next, change the o2 sensor & spark plugs
lastly, change the cat
The dealer did/does change the threshold (or something) for the cats, I have no idea if it applies to your issue, but you could call and ask.
Old Jul 1, 2008 | 12:00 PM
shaikha's Avatar
Thanks Jeffla,
I had the code cleared out yesterday and it has not come up again. I can change the sparks plug easy so I'll do that next. The O2 sensor, have no idea about where to look for it.
Old Jul 1, 2008 | 01:44 PM
techbod's Avatar
if the codes didn't come back why change anything?
Old Jul 1, 2008 | 02:28 PM
wammy18's Avatar
More commonly your code will come back every 20-500 miles at random points I found and is messing up my performance. I know myO2 sensors are on the last leg but need to check my sparkplugs :P
Old Jul 1, 2008 | 04:14 PM
shaikha's Avatar
How bad is it to change O2 sensors?
Old Jul 2, 2008 | 10:04 AM
shaikha's Avatar
wammy18 you were right, I had the check engine light pop up again. Any suggestion on O2 sensor replacement?
Old Jul 2, 2008 | 11:17 AM
wammy18's Avatar
bahhh I have been holding off aswell because I have court coming up where I might not be able to drive anyways But I will ask around and ask my buddy with an s4.. I know parts for the o2 sensor $215.00.... Sadly I have been pretty stupid with getting stage 3 and not checking my spark plugs!! Def do this when replacing or checking the parts. That is fairly easy to do but let me know if you need a step by step with checking the spark plugs. Takes about10-20 mins to check since I have taken the intake out who knows how many times
