Error Code 441???
Old Aug 22, 2006 | 08:20 PM
mikehh's Avatar
Default Error Code 441???
I keep getting the 441 error code on my 2000 A6 Avant, referencing to insufficient purge flow. Does anyone have a hint as to what to look for??
Thanks!!
Old Aug 23, 2006 | 02:25 AM
dankhound's Avatar
Default RE: Error Code 441???
Evap purge valve stuck closed or a broken vacuum line from the purge valve to the engine. Do a search in the a6 and a4 forums. Operation and location is the same on both vehicles and theres plenty of posts to help you along.
Old Aug 23, 2006 | 04:04 PM
mikehh's Avatar
i just replaced all vacuum lines, but i will ckeck for the valve.
thanks for the input!
Old Aug 25, 2006 | 03:35 AM
dankhound's Avatar
If yo ujust replaced all the vacuum lines you may have one incorrectly routed. Also make sure the purge valve is plugged in. Both mechanically and electircally.
DCAV8R
Jan 23, 2023 06:33 AM
aaceve7
Sep 7, 2012 01:08 PM
shaikha
Jul 2, 2008 04:39 PM
NewJ_A4
Feb 3, 2008 01:09 AM
winter001
Jan 8, 2008 07:50 PM
