Discoverd an intresting feature on my 96 A6.
Old Aug 21, 2006 | 01:20 AM
quattromond's Avatar
Default Discoverd an intresting feature on my 96 A6.
I just realized that When I unlock the car twice with my remote on my 96 A6 it will move the drivers seat to the first set memory position. I never realized this before because I never moved the seat around from its setting but today when I moved it around I realized it moves back when I open the door.
What else is supposed to move, I would amagine the mirrors to but mine dont work for some reason. So thats what I found what has everyone else found.
Old Aug 21, 2006 | 01:31 AM
SouthboroAudiGuy's Avatar
Default RE: Discoverd an intresting feature on my 96 A6.
If it's like the C5s, you can actually "link" the remote to a seat memory setting so that it will happen with a single click. I forget exactly how, but a check of the manual and/or a search here should find something on this.
You may also want to do a search on recoding the central locking console with a VAG COM -- there's all sorts of fun things you can do (e.g., holding down "unlock" button rolls down all windows -- GREAT on a hot, sunny day). Check my signature/registing for a link on this.
Old Aug 21, 2006 | 01:43 AM
I don't know but I dont have an A6 owners manual, but if I can get that feauture to I would like that. So if there is a link that would get good.
Old Aug 21, 2006 | 01:59 AM
Search revealed THIS on AudiWorld.com
Old Aug 21, 2006 | 02:37 PM
Boston Driver's Avatar
I am just not sure if that works on the 1996 A6 as well, that reply that SouthboroAudiGuy provided was for a 1998-2004 A6.
Old Aug 23, 2006 | 12:58 AM
It won't, I looked in the owners manual, says you can't.
Old Aug 23, 2006 | 01:07 AM
Bummer. I was hoping that feature went backwards across the model transition. Time to upgrade I guess. :-P
Old Aug 24, 2006 | 03:28 AM
Euge82's Avatar
For my 1998 A6 it has memory associated with each key fob. It adjusts the seat and mirrors. If I put the key in the lock and hold it the windows will roll down.
Also if you get out of the car and realize a window is open if you lock the car with the key, turn it and hold it then windows, they roll up.
Try turning the mirror adjustment **** to the passenger side. When you put the car in reverse the mirror moves down so you can see the curb while parallel parking.
rock on
Old Aug 25, 2006 | 10:26 AM
Yea I would like that to but for some reason my mirrors don't work.
2009A42.0t
B8 Models
Apr 27, 2009 10:36 PM
Armenian
Jan 28, 2009 02:16 PM
raffysaudi
Dec 28, 2008 06:39 PM
Devastata_A6
Oct 24, 2006 05:42 PM
