ethanol?
I am also using gas that contains ethynol (92 octane). I'm not sure what the percentage is, I've looked for it at the pump but it does not say. I will go in next time and ask the manager.
I have not noticed any issues performance wise with my car, seems to run very smooth.
When I first started using it I thought that I was getting less gas mileage with the ethynol. So I tried a couple of tanks of Chevron (92oct), and I actually think I got worse gas mileage with the Cheveron! So now I'm back to ethy, I continue to monitor and keep you guys posted.
2002 A6 2.7T
Cold weather package, ming blue, 20% tint all around
2002 A6 2.7T
I guess 10% ethanol is a pretty much standard now. You will have to find a speciality gas stationthatwill carry petrol without ethanol. However, when you will switch to the one which has 15%, your gasmileage will go south. I have seen thegas stations those sell cheaper, are usually with 15%, likeLiberty and7-Eleven.
My car seems to run fine with ethanol (10% blend) but I do notice a significant drop in mileage, which in my experience has resulted in the cost benefit of ethanol being erased. I plan to run a few more tanks of ethanol in order to get another comparison, but most stations in my area only use ethanol on the mid-grade (89)fuels and since I run premium (92), it doesn't come with ethanol.
There are some stations in the area which do have a premium with ethanol that is a 93 octane, so I might try that and see how it does.
The manual talks about this some. I think the standard recommendation these days is up to 10% should be no problem. In addition toany decrease in mileage (which I can't verify) the main problem with ethanol is that it will eat away many of the rubber/plastic parts in the fuel system. As far as I know, all cars today are designed so that they can handle it. I use a gas (QuiK-Trip) that doesn't use ethanol, at least I don't think they do because it's not posted on the pumps, which I believe is a requirement.
Like Costner, my A6 runs fine with 10% ethanol but it gets less mpg. I prefer to use Shell or Mobil midrange. It runs fine on that, too, and I don't notice any difference in mpg using premium. I am not a lead foot so I've never experienced any pinging.
