Evolution; PosiQuiet
Old Apr 6, 2009 | 06:53 PM
chefro's Avatar
Default Evolution; PosiQuiet
Is any of you guys familiar (to the point of having used or using them in your car; not just by name) with these two brands of brake pads?
Evolution are "ceramic".
PosiQuiet are "semi-metallic"
I would appreciate any educative input.
Thanks.
Old Apr 6, 2009 | 08:03 PM
nm3210's Avatar
Hawks HPS all the way. But to answer your question, no I haven't heard of either one of those, after looking them up it seems that PosiQuiet makes corvette brake pads (on ebay)??
edit: found a few links
Power Stop - Evolution: http://www.exoticperformanceplus.com...x.html?item=18
PosiQuiet: http://www.autoanything.com/brands/102A24552.aspx
-They seem a little cheap, but i don't know for sure...
Old Apr 8, 2009 | 11:42 AM
chefro's Avatar
PBR?
Mintex?
Come one, I don't believe for a second that everybody in here only uses expensive Hawks or EBC yelow, green, blaujandarme, or whatever else color they come in.
Old Apr 8, 2009 | 04:51 PM
trdltly's Avatar
Need to have the title as "Brake Pads" or similar. If you search for brake pads you will find more information as to what everyone uses.
Old Apr 8, 2009 | 06:10 PM
chefro's Avatar
Don't mean to be rude. It would be last thing to do when looking for input or advice.
However... It happens that most often I DO use the "search" feature, even for other people in an attempt to help them.
If I would have wanted to see what EVERYBODY that remotely posted what brake pads they use, I would have indeed titled the post "Brake Pads", OR more probably just do a search on "brake pads", and start browsing the returned results.
The point was to see if anyone USED or USES these particular brands. Obviously, nobody does.
Thanks for your input, and for everyone else's silence. Sometimes is a good indicator in terms of an "answer".
ttalms
Mar 2, 2008 10:28 PM
Ports6689
Jul 26, 2006 09:55 PM
JValentine13
Dealerships
Apr 11, 2005 08:32 PM
