Filling the tranny - drain plug/ fill plug???
Old Dec 14, 2009 | 09:27 PM
hottubbrad's Avatar
Default Filling the tranny - drain plug/ fill plug???
I am going to drain my tranny and I see the drain plug. I also see a huge plug (with a huge hex socket head bolt).
As I cannot locate a fill plug on the side of the tranny, where do I fill it??
Thru this large hole?? Am I going to get 4 liters into this horizontal hole?
Thanks
note: 2003 A6, 2.7, tiptronic auto 5HP19FLA
Old Dec 14, 2009 | 10:10 PM
hxgaser's Avatar
Drain plug is the smaller allen head. The fill plug is the 17mm allen. You need a pump with a flexible tubing attachment.
Old Dec 15, 2009 | 11:47 PM
Jackmup's Avatar
Do yourself a big favor and read up on how to change the fluid it's not a typical fluid change if you jump in you'll be sorry. Also if you get a blau kit order 2 extra liters they do not send enough it should take about 6.3L.
Old Dec 16, 2009 | 02:13 PM
m000035's Avatar
Believe it or not, it is designed to be filled from the bottom. The fill port has a tube that goes up a bit into the transmission. This is to help prevent overfilling --- Any excess fluid drains right back out. Never really liked the design, but what can I say... I didn't build it!
Read -- and understand -- the instructions before doing this. The transmission needs to be up to temperature when the fill plug is reinstalled.
Old Dec 16, 2009 | 11:24 PM
Jackmup's Avatar
no kidding it'd designed so you don't over fill it. So well you can't fill it period.
cmacelo121
Dec 11, 2009 08:38 PM
nemohm
Nov 24, 2008 11:24 AM
wolfdog
Aug 22, 2007 11:55 PM
seabassx
Nov 14, 2006 02:14 AM
werkwitdis
Jun 4, 2006 02:07 AM
