Tranny drain plug seal
Old Nov 21, 2008 | 04:24 PM
nemohm's Avatar
Default Tranny drain plug seal
For those who have serviced their tiptronics-
What do you do with the drain plug seal?
It seems to be integrated and Audi sells it as unit - plug and seal.
Does anybody have a solution for the seal w/o buying a new plug?
(Or source for inexpensive plugs)
Old Nov 21, 2008 | 07:34 PM
hxgaser's Avatar
I sort of don't remember having a seal around the drain plug. If there was one, then it would have been a rubber o-ring(?)
Old Nov 21, 2008 | 08:34 PM
nemohm's Avatar
It's not a rubber o-ring, but flat greenish washer-resembles the plumbing type of seal.
Located in recess between the thread and the head, smaller diameter than the thread, couldn't get off w/o damage.
Looks like it got shrunk after assembly,
I.ve got once a new plug for $20 cad, but there has to be way to reuse he plug with a new seal!
Old Nov 22, 2008 | 07:00 PM
68jcode's Avatar
I reused the drain plug without putting a new seal on it and I have not had a problem (changed my trans fluid about 4 weeks ago).
Old Nov 24, 2008 | 11:24 AM
hxgaser's Avatar
Whenever I run into washer and miscellaneous item issue, I go pay a visit to my local hardware store. (Not a big box store like home depot, but a small mom and pop store) You can pretty much get any kind of washers, ball bearings and etc. Perhaps it is a fiber washer? Anyways, if you still have pieces of the old one, take it to a hardware store and see if thet have anything similar. I usually spend more money on gas driving to the hardware store than the actual washer.
lespaul2510
Aug 1, 2010 02:19 PM
hottubbrad
Dec 16, 2009 11:24 PM
ltcoljdf
Jan 5, 2007 09:03 AM
werkwitdis
Jun 4, 2006 02:07 AM
