First Mod
Old May 7, 2007 | 04:37 PM
votblindub's Avatar
Default RE: First Mod
ORIGINAL: CamoA6
get ready to replace your MAF...
ah, thats only if theres way too much oil on it, right?
Old May 7, 2007 | 04:48 PM
Joeski's Avatar
ORIGINAL: votblindub
ORIGINAL: CamoA6
Absolutely correct! If it is oiled properly, there should not be a problem. I have been using mine for about 20K and its been perfect!
OOOO
Old May 7, 2007 | 05:41 PM
Khardysius's Avatar
In regards to the MAF, will I get an error or is this something that just NEEDS to be done?
I did "dab" the K&N with a paper towel before putting it in as I read that in a previous post.I did not see any excessive oil on the paper towel so I just threw it in without a second guess. I haven't seen/heard any issues.
Although, as it was PARKed in the garage, I stepped on the gas to get it up to 3.5-4kRPMs then let off.Right as I do that and before the RPMs rise there is not even a half of a second suck noise. Like air is being sucked in. Is this normal? Or can anyone with a 4.2 try the same thing and see if they can replicate? I never really did this before I replaced the air filter, so I don't know if this is SOP or not. I don't really want to put the old filter back in to see as it is a minor PITA.
Any help is appreciated.
Old May 7, 2007 | 06:20 PM
Joeski's Avatar
If the MAF gets coated with the K&N oil, it will cause the MAF to fail and itwill throw a CEL because it will not be able to accurately read the air flow passing through the intake system.
OOOO
Old May 9, 2007 | 03:32 AM
formulagigi's Avatar
don't stress so much, it is just a drop in! Just easy on the oil, and you'll be fine. Been running them with no issues, My buddies 2000 S4 has had one for 3 years, NO ISSUES either.
