Front seat stuck
My 2000 A6 passenger front seat is stuck almost all the way back.(lower part of d seat) All other power adjustments work, up/down But not fwd / back adjustment. Is there a breaker that possibly tripped and can be re-set? Or is it the switch that went bad? Any help will b much apreciated!!
if everything else works your problem lies in either the switch or the motor. easiest way to check is to unbolt and tilt the seat back you can unplug the seat motor and check for voltage at that plug while holding the switch.
2kaudi
Oct 31, 2007 08:04 PM
