fuel grade
Old Nov 11, 2007 | 07:40 PM
avantgradeA6's Avatar
Default fuel grade
Would it be ok to run 89 octane in a 2.8, would using 91 make a big diffrence when concerning furture reliablity, thanks so much
Old Nov 11, 2007 | 08:32 PM
MiniSpdRcr's Avatar
Default RE: fuel grade
It is fine, I dont beleive it will hurt the engine unless it runs below the 87 grade level, but the manual recommends 91+ octane. If I am wrong please someone correct me.
From the manual: The recommended gasoline octane rating for your vehicle is 91 aki / 95 ron. Do not use any fuel with octane ratings lower than 87 aki / 91 ron otherwise expensive engine damage will occur. Your vehicle may also be operated by using unleaded regular gasoline with a minimum octane rating of 87 aki / 91 ron. However, using 87 aki / 91 ron octane fuel will lead to a certain loss of engine power.
Old Nov 11, 2007 | 08:33 PM
alias747's Avatar
What does your owners manual say? It's not worth the 1.50 per tank you are saving to go against what the manufacturers of the car recommend. Thats all I say.
Old Nov 11, 2007 | 08:42 PM
Audi recommends 91, but no lower that 87, im really just wondering if 89 might cause problems after constantly using it for a long period of time, thanks for your input, and I suppose i should just play it safe with 91
Old Nov 11, 2007 | 08:55 PM
MiniSpdRcr's Avatar
To tell you the truth I had a period where I had to run 87. It ran fine for the two months with no problems what so ever.
Old Nov 13, 2007 | 03:16 PM
rvt1000's Avatar
Always use 91, better yet 92, I have necer tries 87 in it, but truly don't want to find out what might happen.
Old Nov 13, 2007 | 04:06 PM
Jeffla's Avatar
Look here: https://www.audiforums.com/m_636476/tm.htm
This topic has been discussed to death already.
Jeff
Old Nov 13, 2007 | 06:21 PM
Wow, your not kidding!! but very informational and interesting, now im most definitely sticking with 91
Old Nov 13, 2007 | 09:36 PM
catdog's Avatar
I definately notice a certain loss of power with 89 octane. It's worth the extra couple of bucks for the better driving experince.
Old Nov 13, 2007 | 10:43 PM
zurn's Avatar
I have never used 89... stick with the best for the best, its only a couple more dollars no matter what car you drive..............
