Fuse 14 blown, any ideas
Old Dec 19, 2004 | 06:01 PM
ghuston's Avatar
Default Fuse 14 blown, any ideas
My car is responding in a similar fashion to post by HoosUrDaddi in message https://www.audiforums.com/showProfile.asp?memid=3360. Replaced fuse and blows again. Big difference between my problem and his is that only work recently done to my car was oil change and car wash. Problem appeared following this.
Any help would be appreciated.
Thanks
Gary
1998 2.8 A6 Quattro
Old Dec 20, 2004 | 04:50 AM
flyboy's Avatar
Default RE: Fuse 14 blown, any ideas
what does fuse 14 supply power to?
Old Dec 20, 2004 | 12:30 PM
mrracing's Avatar
There is a TSB (technical service bulletin) on Fuse #14 blowing. It's a pinched or chafed wiring harness in the sun visor. It says wiring pinched or chafed by mounting screws holding sun visor up. There is a repair harness available from the dealer, it's VAS1978.
You may be able to repair it yourself by removing visor and repairing wires then rerunning them away from the mounting bracket.
Old Dec 20, 2004 | 03:51 PM
Jestnomen's Avatar
6th Gear
I find a little piece of tin foil instead of a fuse works better. (j/k!)
Old Dec 20, 2004 | 03:53 PM
mrracing's Avatar
I did that once when I was in highschool. Everything worked fine until I got an electrical fire under the dash. Looked like Cheech and Chong when I opened the door to get the hell out.
Cribbs767
Mar 18, 2015 04:29 AM
wvning
Dec 5, 2008 10:06 PM
madmx
Apr 6, 2008 01:34 PM
Quattro_1.8t
Oct 27, 2007 10:14 PM
eddieg
Nov 12, 2006 06:05 PM
