FYI: SYLVANIA FOG LIGHT
Old Mar 11, 2007 | 09:18 PM
RIA6's Avatar
Default FYI: SYLVANIA FOG LIGHT
So one of my fog lights burnt out yesterday. I tasked myself to replace it today. End result mission accomplished...
BUT! I decided to just put Silverstars. So i went to the local parts store and picked up the reccommed H3ST bulbs... I then return, got everything taken around and the new bulb in; although it looked odd compared to the bulb i took out... the old blub had two male ends off the base, the new bulb had one male end off a wire off the base, didnt think anything of it... till it didnt work, then i though bad bulb, these are mass produced. tried the second no dice. came in side check Sylvania's website... it also says for the A6 to use H3ST bulb. I then return to the store in search of the bulb matching the two male end setup. This is the H7ST bulb!!
So after returning home again I finish the job, then do the quick Fog light mod (looks great by the way) and allset.
I just took a quick look again at the Sylvania website and the RS6 is supposed to use the H7ST bulb. I found that interesting.
Old Mar 13, 2007 | 08:24 PM
pkhuman78's Avatar
Default RE: FYI: SYLVANIA FOG LIGHT
Let me say on the behalf of people, like myself, that have no patience...THANK YOU! I don't know about anyone else but the closest parts store to my house is 30 Minutes away...so I'm putting a note to self in my glove box so that I'm not extremely angry when I try to replace a burnt out fog light.
Old Mar 14, 2007 | 02:33 PM
ppgoal's Avatar
What year A6? What foglight mod did you do?
Old Mar 14, 2007 | 03:31 PM
RIA6's Avatar
2003 3.0L
the foglight rewire (so you can use your foglights as running lights)
http://forums.audiworld.com/a6/msgs/375675.phtml
(found on Southboro's Registry page)
Old Mar 14, 2007 | 05:58 PM
mustang196718's Avatar
ORIGINAL: RIA6
2003 3.0L
i did this mod on my 2000 4.2 as well. works great especially because most of the time that you want people to see you easier, you don't need the xenons on.
Tourbo24
Aug 20, 2010 06:58 PM
Optical Serenity
Nov 13, 2006 04:04 PM
KarlMarx
Aug 10, 2006 03:02 PM
A4 the Quattro
May 9, 2006 05:32 PM
JDCrowe
Jan 9, 2006 08:52 PM
