Get better & better Now oil lamp flashing
Old Feb 15, 2006 | 07:35 PM
JG's Avatar
JG
Default Get better & better Now oil lamp flashing
Having come to terms with the power steering problems (New pump going on tomorrow) I have just come across a potential heart stopper.
Driving up to a junction, clutch in, revs die - car stalls, pop clutch to restart, same thing happens- canter through junction by popping clutch then able to dip clutch and give it some throttle everything returns to normal-ish.
10 mins later the same thing happens while pulling into park at home, this time with oil can symbol flashing in Diagnostic section and buzzer alarm. Handbook advice "Stop the car and request roadside assistance". This sounds v bad.
Can anyone reassure me what might be causing it?
Having provided excellent service for 2 years it seems that this might be the beginning of the end of the relationship
Thanks in advance
JG
Old Feb 15, 2006 | 08:52 PM
techbod's Avatar
Default RE: Get better & better Now oil lamp flashing
I suppose you checked you have oil in there?? other problems could be oil pump failed/timing belt issue
Old Feb 20, 2006 | 10:12 PM
JG's Avatar
JG
Oil OK
Hoping thta it is just the oil pressure sensor switch - the cheapest alternative. Worst case is scored pistons big end going etc...Many dollars.
civitanove
B8 Models
Dec 22, 2014 06:57 PM
d0rk
May 19, 2009 02:55 PM
bilney1
B7 Models
May 27, 2008 03:10 PM
pa4ul
Mar 10, 2008 12:22 PM
ronakc
Jun 21, 2007 10:53 AM
