Problem with headlights!
Old Feb 21, 2006 | 04:11 PM
gilee_8's Avatar
Default Problem with headlights!
Sup guys.
I just made a 500miles trip from NY upstate to Pittsburgh PA. I drove there no problem but after 2 days staying in Pittsburgh, and when I head back, I have a problem with my headlights. When I turn on my headlight low beams (not HID) after 1-2 second, I get a warning light on my dash (I believe it's a light bulb shape with a X on it) so I stopped and check. my headlight (lowbeam) is out. both of them! but the fuse for 20 & 21 are good.
I did rewired my foglights over 2months ago so they can go be lite without the headlights, so I drove 500miles with only foglights.
if I turn on the headlight switch, then I can turn on my highbeam but just pushing signal switch in (but annoying to have the warning light on), if I don't turn on the switch to headlight, I can keep pulling on the signal switch to turn on highbeam while holding it.
Bascially everything is working fine, highbeam, all foglights, signal, etc. Except both my headlights are out the SAME TIME, so I am doubting it's the light bulbs!
Do you guys think it's the light bulbs? (they are brand new 5 months ago)
Any help will be great, since driving at night with only foglights are horrible!
Thanks all.
Gil
Old Feb 21, 2006 | 06:45 PM
beefski's Avatar
Default RE: Problem with headlights!
i would pull the bulb and using a tester check to see it there is juice goung to the plug
awd_crazy
Sep 21, 2010 02:55 PM
warmachine000
Aug 14, 2008 12:47 AM
LeAudi19
Mar 16, 2008 09:14 PM
arb
Jul 28, 2006 06:04 PM
Lipscomb29
May 12, 2005 05:49 PM
