Got my Engine Codes whats neXT!!
Old Aug 3, 2007 | 04:27 PM
jasmix's Avatar
Default Got my Engine Codes whats neXT!!
ENGINE CODES
Do I have to replace everything these codes say or can this be caused by one sensor and is like a chain reaction.
The car runs/drives fine... with some vibration on idle its very annoying.... so where do I start...
P1141
P0300
P0301
P0303
P1606
P1127
P1129
I already replaced/cleaned;
PLUGS
COIL
IGNITION WIRING
CLEANED THE INJECTORS
FUEL FILTER
I have a 1999 A6 Quattro 2.8
so what now?
Old Aug 4, 2007 | 03:48 PM
jasmix's Avatar
Default RE: Got my Engine Codes whats neXT!!
Im confused as ****.... I cant keep buying all this stuff there has to be an explaination.
any help guys!!
Old Aug 6, 2007 | 01:09 AM
jasmix's Avatar
??? so i guess i have to start replacing everything?
Old Aug 30, 2007 | 08:56 PM
ulfdre's Avatar
Hi,
I do have the same problem with a 99 2.8 A6. The codes are P1129, P1127, P1141 and P0411. I am not quite sure where to start with the root cause analysis. I read it could be as simple as a leak in the air intake line. I also found out that the MAF and O2 sensor could be the reason. Let me know, how you fixed the problem. The rough instable idling is really annoying I want to get rid of it.
Staudi911
Jan 15, 2015 03:20 PM
JPJ2007
Apr 17, 2009 08:54 AM
j_dinan
Nov 10, 2008 11:43 AM
30vQuattro
Mar 6, 2008 10:13 AM
