h&r springs, can I just get those?
Old Jul 14, 2008 | 04:22 PM
alexfunari's Avatar
Default h&r springs, can I just get those?
Hey i want to up H&R SPRINGS on my car to lower it like and inch or so, can I just get away with getting the springs?
Its the A6 1998 2.8 with 145000 miles.
Old Jul 14, 2008 | 04:45 PM
massboykie's Avatar
Member
Default RE: h&r springs, can I just get those?
...can I just get away with getting the springs?
Hey Alex
I believe you can, but I believe (from what I've read) that your stockshocks might fail earlier as they are now working in a different "range" and the springs are also stiffer which work them harder. If you are going to do the job yourself, you can always do the shocks later.
Then again...the ride quality would probably be much better with new shocks. You said you have 145K on the car? Ever replaced the shocks? Just something to keep in mind
Cheers
Massboykie
Old Jul 14, 2008 | 11:00 PM
formulagigi's Avatar
You can but shouldn't IMO and based on my experience., I did H&Rs only to save $ and ended up going back for shocks,
Old Jul 14, 2008 | 11:01 PM
The H&R will lower the car much more than 1", probably 1.5 and 1.75". They have a more aggressive spring rate and
Old Jul 14, 2008 | 11:04 PM
... lower more than the Eibachs for example. The car will look better and handle better due to lower center of gravity but...
Old Jul 14, 2008 | 11:05 PM
they will wear your stock shocks much faster, especially yours if they are still the original ones at 145k miles. Your car will
Old Jul 14, 2008 | 11:06 PM
bounce and bottom out in some places I am afraid. I would do shocks and springs at once to save $, or you'll pay labor twice.
Old Jul 14, 2008 | 11:07 PM
sorry lost my first reply, long post, won't let me post more than a line,
Old Jul 14, 2008 | 11:35 PM
oc_audica's Avatar
you CAN do it, but it's DUMB
just save up your money especially if you're already doin the labor to remove the shocks to install the springs
porschenaround
B7 Models
Mar 9, 2018 07:59 PM
88notchblown
Sep 27, 2009 01:34 PM
Quattro190
Aug 11, 2008 11:57 AM
VW01AUDI00
Mar 27, 2007 10:56 PM
jrac79
Feb 7, 2006 08:19 PM
